Activity Forums VEGAS Pro Mute/Solo sets project marked unsaved but can’t undo
  • Mute/Solo sets project marked unsaved but can’t undo
    Posted by Jim Greene on November 18, 2010 at 1:46 pm
    This is sort of trivial, but here is a bug: When you set a track’s Mute/Solo button, the project is flagged as changed, but this action is not registered on the “undo” stack. So for example, if you make a change by adding an effect, then change the solo or mute button on any track and then do an “undo”, the “undo” operation will be the effect, not the track setting.
    This may seem trivial, but when I make a change I often instinctively use the “undo” by pressing ctrl-z to revert back. So in my mind I will sometimes think I am doing an “undo” to the track setting, but in reality the previous project change will be undone. This has burned me.
    To me this really is a bug, and has been here forever, and I wish it would be fixed. It actually seems like the only time the project can be flagged as dirty (needs to be saved) but can’t be undone.
    -Jim.
    Jim Greene replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
