Activity Forums Adobe Premiere Pro Mute Individual Video Clips
  • Mute Individual Video Clips
    Posted by Zoe Griffiths on June 8, 2014 at 11:24 am
    Hello all,
    I’m currently switching over from FCP to PrePro CC. While most things work in very similar ways, there are a few things I’m finding hard to locate or use.
    One of these is the ability to mute/hide individual video clips on the timeline. This is really simple in FCP, but I can’t seem to find the same action in PP – can anyone help?
    I know you can use Toggle Track Output to mute the whole track, but how do you mute individual video clips?
    Any help would be really appreciated.
    Thanks so much,
    Zoë
    Mike Anderson replied 11 years, 2 months ago 4 Members · 3 Replies
  • Ann Bens
    June 8, 2014 at 6:59 pm
    Alt click on audio part of the clip, right click and disable.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Jimmy See
    December 22, 2014 at 1:26 pm
    I realise this was a long time ago but I imagine many FCP 7 editors will want to know this as few other platforms seem to do it and everyone loves it. It actually is possible in Premiere, and can be made to function identically to FCP 7 which is really great.
    Ann, I believe the ‘muting’ that Zoe is referring to is actually not related to sound, though it uses the term ‘mute’. This is just Final Cut parlance, you’re actually muting video, not sound, that is basically switching on or off the visibility of particular video clip rather than the entire track the clip resides on. You can also use this technique to mute audio too, or both at once with linked selection, but primarily it’s usefulness is with video. It’s just an on off switch for clips on a timeline.
    I’m using Premiere Pro CC, and I have my keyboard mapped to FCP 7 so I don’t know if this doesn’t work in previous versions, or if certain key commands are in use on the standard Premiere Keyboard that aren’t on mine. That said, here’s what you do:
    The ‘muting’ we’re referring to as FCP users is actually much more logically named as ‘enable/disable’ a clip. You can access this via right clicking on a clip in the timeline. It’s also mappable to the keyboard. Change your keyboard preferences and search ‘enable’ you’ll find a setting for enabling or disabling clips on the timeline. Map this to ctrl + b and it’ll but just like the good old days again for FCP 7 users. Or map it to whatever you want, but I’m set in my ways so I like the familiar keyboard shortcuts.
  • Mike Anderson
    July 14, 2015 at 11:59 pm
    I just did a bunch of digging because I was wondering this same thing (I was going crazy trying to figure this out), and the easy way is to just hit Command + Shift + E, or select a clip and go to Clip > Enable
    Really simple once you know it, but damn it was hard to find!
