Mute Event
Posted by Roger Bansemer on January 29, 2013 at 9:17 pmIs there a keyboard shortcut to mute a single event on the timeline?
“Z” does it for a track for not for an event.
ThanksGraham Bernard replied 13 years, 8 months ago 2 Members · 8 Replies -
Graham Bernard
January 29, 2013 at 9:29 pmThere IS a KB Command waiting for you to assign a KB combination of KeyStrokes.
Open the Customize Keyboard and Type in the Global Option: MUTE
I just did and got back exactly what you’re after, but you do NEED to assign a KeyStroke. I used Ctrl+Z. You now click on an Event and hit Ctrl+Z and it Mutes that Event. Works for both Video or Audio.
Enjoy!
Grazie
Cameras: Canon XF300 and two elderly XM2s -
Graham Bernard
January 30, 2013 at 7:38 amMY BAD!!
Not Ctrl+Z, that’s the UNDO switch. I’ve now changed my MUTE option to Ctrl+”\” – ignore the quotes.
So, Ctrl+\ .
Best regards
Grazie
Roger Bansemer
January 30, 2013 at 11:44 amGrazie, I’m looking to mute (and unmute) on a single event and not the entire track. Can’t seem to find that option.
I do a lot of multi-track editing and there are many times when after expanding the tracks that I want to use a different event than I’ve chosen when doing the multitrack editing.
Graham Bernard
January 30, 2013 at 12:00 pmDid you still not find it in the Key Board commands?
G
Graham Bernard
January 30, 2013 at 12:17 pmRoger? This is weird . . I’ve got this via an email from you:
“Thanks Grazie,
Just what I needed.”But your acknowledgment didn’t appear in your Cow reply above?? Which made me think you hadn’t been able to locate the necessary . . ?
Hmmm…
G
Graham Bernard
January 30, 2013 at 12:20 pmI hope this video will help.
Roger Bansemer
January 30, 2013 at 12:42 pmThanks Grazie for taking time to do that for me.
I missed finding it because I didn’t see the “global” button and just searching without that didn’t seem to bring up the mute for an event but just for the entire track.
Anyway, got it now and thanks again.
This will really save me a lot of mouse work.
Roger -
Graham Bernard
January 30, 2013 at 1:09 pmYeah, easily not done, hence I made the point:”Open the Customize Keyboard and Type in the Global Option”
Cheers
Grazie
