Activity › Forums › VEGAS Pro › mute event shortcut
  • mute event shortcut
    Posted by Emilio Arteaga on May 21, 2009 at 11:10 am
    Hi
    I can`t find the shortcut to mute a piece of audio event,
    I mind a shortcut for:
    Switches / mute
    “Z ” mute all the track.
    thanks
    Emilio Arteaga replied 17 years, 3 months ago 2 Members · 2 Replies
  • Graham Bernard
    May 21, 2009 at 6:28 pm
    You need to set one up – as far as I can tell.
    Go:
    Option | Customise Keyboard | Click on GLOBAL | search on “Mute” | this should return “Edit.Event.Mute” and then type in a Shortcut Key – I’m using Ctrl+Shift+A – a bit clumsy . . .
    Once back at the time line:
    Click on Audio Event and do your KB SC it’ll go MUTE! Do it again and you de-mute your Audio Event.
    This is NOT thru the properties, although it is revealed there, it is what you wanted. You could even set up a Toolbar Icon for it too!
    Grazie
  • Emilio Arteaga
    May 26, 2009 at 10:05 am
    Thanks very much Graham, your tip works fine for me
    I put Ctrl+1 because is a more “short”cut.
    emilio
