Activity Forums Adobe After Effects Mute and unmute effects on the go
  • Mute and unmute effects on the go
    Posted by Telion Fondrad on March 28, 2018 at 6:50 am
    I don’t know how to call this so it might be a reason why I can’t find a solution. All I need is to disable and enable effects on the timeline when needed since I am just adding additional effects to the already rendered project. Is that possible to make that this way or I must split all the scenes in my video and apply effects to those which need it?
    Telion Fondrad replied 8 years, 5 months ago 2 Members · 4 Replies
  • Richard Garabedain
    March 28, 2018 at 2:40 pm
    Yes..you see your layer has the motion blur option and the 3d option…well see that fx symbol. if you uncheck it, all the effects on that layers are turned off.
  • Telion Fondrad
    March 28, 2018 at 6:17 pm
    My bad, hard to describe for me.
    I have already rendered video. Some compilation of stuff. Not I want to use AAE to add shake effect to some part of it(keyword: some parts) and to change lighting/colors on other parts. I can just split the rendered video into pieces which is probably what I need to do and add effects separately to each one of them. But I am curious if that is possible to do the other way.
    So, for example, I have only 1 source on my timeline, I want the shake effect work from 0 to 10th seconds and then mute, after which unmute for another 10 seconds at the 30th second of video.
    I guess this should make it much more clear to answer the question.
    March 28, 2018 at 6:57 pm
    okay..do you know how to make the wiggle expression then tie the values to a slider control? then you could animate the slider to control the wiggle
  • Telion Fondrad
    March 28, 2018 at 11:01 pm
    Well, you’re definitely right and I always knew that’s the way to go. But I am used to Sony Vegas from very past and the project was already started there. Now I am just looking for the best way to make it work here. I am sure will do future projects in Premiere Pro, I discovered some interesting functionalities and benefits of using it too but right now I need to do work with what I have ☺
