Activity Forums Adobe After Effects Expressions “must be scalar” error
  • “must be scalar” error
    Posted by Dagur Maunason on May 27, 2019 at 2:06 pm
    Hi all,
    I’m trying to have a layers scaling follow a Slider control, which works just fine, even with a time offset for the child layers in point implemented. The last functionality I want is to multiply the incoming value from the master with whatever value the child was originally set to, so that the processed animation ends up at for example 80%, instead of 100%. When I input the solution below I get an error stating “one argument to mul() must be scalar”. I’ve tried to searching for an answer but to no avail.
    Any help would be greatly appreciated!
    offset = thisLayer.inPoint;
    orgValue = transform.scale;
    animValue = thisComp.layer("Anim Master").transform.scale.valueAtTime(time - offset);
    newValue = orgValue*animValue;
    newValue
    Dagur Maunason replied 6 years, 11 months ago 2 Members · 3 Replies
  • Dagur Maunason
    May 27, 2019 at 2:28 pm
    I just managed to finally hack a solution together that works, but if anyone know a cleaner/smarter way to do this please enlighten me! And also to know how to do this for example for a 3d layers position would be awesome aswell ☺
    Cheers!
    orgValueDiff = 100-transform.scale;
    newValue = animValue-orgValueDiff;
    [newValue[0], newValue[1]-100]
  • Tomas Bumbulevičius
    May 28, 2019 at 2:48 pm
    Dagur – for 3D, you just need to add another dimension, with an array index of 2.
    [newValue[0], newValue[1]-100, newValue[2]]
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Dagur Maunason
    May 29, 2019 at 3:18 am
    Thank you Tomas!
