Activity › Forums › Zaxwerks › must be a poor set up
  • must be a poor set up
    Posted by Roger Burton on September 21, 2005 at 5:27 pm
    Hi all…this is a repeat of a previous post with some more detail ’cause I can’t get invig to do anything much at the moment…really need some help please to try and narrow down the problem I’m on a big PC with plenty of ram but I’m struggling to make any adjustments in the set-up window…really simple invig stuff using a couple of Illustrator word…I can’t even change the edges….the set-up window seems to go into it’s own thing ….numbers change text flashes…parts of the window go blank…sliders refuse to budge or move on their own…poltergeist comes to mind….is my PC haunted ?…why should the window take minutes (literally) to refresh I’ve trieds working in wirefram with everything else turned to low res.. I have an Nvidia quadro FX 1100 (drivers updated) with AE 6.5, Invig pro 405, XP pro 2 gb ram (anything else I can tell you) I’ll keep trying but any advice as to where to look would be good…thanks everyone…Roger?
    Roger Burton replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
