Activity › Forums › Adobe Premiere Pro › Music video
Music video
Posted by Evalene Brewer on May 6, 2005 at 9:27 amI have finish a music video. the client wants the audio only on a cd. I need some help please. Is there a program i can use to do this. Thank you in advance for your help.
Aanarav Sareen replied 21 years, 3 months ago 4 Members · 7 Replies -
David J
May 6, 2005 at 9:42 amGiven the forum you have queries, I assume that you have Premiere. I also assume you have the video on computer in a format that is acceptable to Premiere and that you have a CD burner and supporting software.
Export the audio from the timeline in WAV format and then use a CD-burning program to write this track to an audio-format CD.
If your starting point is not as I have assumed, then post more details of formats and available editing software/hardware.
Steven L. gotz
May 6, 2005 at 3:21 pmThe software available at https://www.musicmatch.com is very easy to use to burn a CD from WAV files.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Evalene Brewer
May 6, 2005 at 7:16 pmThank you both very much for the help. I am sorry I did not give you more information it was a over sight. Thank you again
Evalene Brewer
May 6, 2005 at 9:28 pmI am using premiere pro. Using easy creator 6 for burning. I was able to burn the CD but it only play on the computer. I cannot play it on my bose player or other players. I would appreciate your help.
Evalene Brewer
May 6, 2005 at 10:07 pmThank you very much Aanarav. I did not use the music setting. I burn it the second time using the music setting. thanks again
