Music dropping out
I am working in FCP 7.02 on a Quad core intel mac. I am noticing that music (which is aif 48khz 16 bit) seems to be dropping out in my sequences. Meaning suddenly the music which was there last time I was working is suddenly gone. I don’t mean the tracks are gone, but when you play the sequence the music will be playing and then suddenly drop out for a few seconds or the rest of the track. When I match frame the track it shows this as well that there is just nothing there for certain parts of the track for which I know music exists. If I check the original file everything is fine, and if I re-insert the track from the original into the timeline everything is fine. This makes me worry because I can’t check every second of all my music every time I want to output to make sure it is all there. I have tried relinking the music and it makes no difference. I have also trashed my preferences as well.
We have 2 other edit rooms with identical media and they have no problem with my sequences.
Any ideas?
Dan
