Activity Forums Adobe Premiere Pro Music audio, enchance dynamics
  • Music audio, enchance dynamics
    Posted by Lauren Michaelson on August 15, 2016 at 2:51 pm
    Hey,
    How can I make my audios loud parts more louder and silent part more silent? I want to edit a clip of piano music. I tried the effect, “Dynamics”, but this is not a good tool: the audio always ends up sounding unnatural and bad. Maybe something in adobe audition, although I am not so familiar with that program.
    Joe Barta iv replied 10 years ago 4 Members · 5 Replies
  • Lauren Michaelson
    August 16, 2016 at 9:18 am
    keyframe, no. It would not be consistent enough and would require an awful amount of work.
    There must be some tool that does this simply. If you can imagine an audio and its waveform, or whatever u call its picture u get, and make it more exaggerated, so it looks more spikey. That is what I think would create the effect I am looking for
  • Lee O.
    August 17, 2016 at 4:59 am
    I think what Lauren is looking for is to expand the dynamic range of an audio clip in general. I’m not in front of my editing computer right now, but I’m pretty sure under the dynamics processing effect in Audition you can select an expander preset and tweak that as you wish, or design one. When I’m not on this notebook PC I can look more specifically. You’d basically be doing the opposite of what I’ve done at times to try and tame dramatic peaks. So yeah, look under dynamics processing for an expander.
  • Lauren Michaelson
    August 28, 2016 at 8:28 pm
    The expander sets a threshold limit, which is not what I want.
    What I want is like this, Ill try to describe it, or what I think what I want. So, you have the, what do you call it, sorry Im a complete noob, its the picture of an audio clip, looks like a spiky long thing. Its the waveform? Anyway, if you can understand what I mean, it is spiky and the spikes indicate louder noises and the lower parts indicate more quiet passages. So my whole idea is, if you exaggerate this waveform or what you call it, then it will look much more spikey. So the spikes grow bigger and the lower parts grow lower.
    This is a really simple concept, right? There must be some king of automatic way to do this. this would make a uniform change in the dynamics as far as I can imagine and think.
    Ok, thanks for answering my stupid questions, Im a complete idiot if you didn’t figure out already, so thanks for your patience
  • Duke Sweden
    August 28, 2016 at 11:01 pm
    Hey, there’s only room for one complete idiot around here and I’ve got that job for life!
    In the meantime, what you could do is highlight your low passage, choose the noise removal plugin, then reduce the effect it has so that you’re not completely removing your low passages. Then just increase the overall clip’s decibel range. That’s probably as close to automatic as you can get.
  • Joe Barta iv
    August 29, 2016 at 2:28 pm
    Click to highlight the clip in the sequence. In the top dropdown menus select Clip/Audio Options/Audio Gain. Then click on the Normalize Max Peak to 0dB button in the pop-up window.
    Does that give you what you are looking for?
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
