Activity Forums VEGAS Pro Multitrack, Expansion, and losing Pan/Crop
  • Multitrack, Expansion, and losing Pan/Crop
    Posted by Ross Stark on July 7, 2021 at 6:27 pm
    Hi, all!
    I just completed edit of a multi-track, live concert with 5 camera angles. Edited in multitrack. As I reviewed edit points and corrected things, I also used event pan/crop tool to add some needed motion or composition corrections. I would now like to Expand to Multiple Tracks so that I can apply color correction at the track level as opposed to the event level (apply it once with MAYBE a few automation points as opposed to applying all 700 times that track is used).
    When I expand, I lose my event pan/crop edits. Is there a way to accomplish the Expand function while keeping pan/crop edits, or am I just going about this all wrong?
    Jay Zee replied 5 years, 1 month ago 2 Members · 1 Reply
  • Jay Zee
    July 10, 2021 at 9:28 pm
    The soon to be released 19 will include, according to Company ads, an “adjustment track”….we’ll have to see exactly what that is, because the info is really skimpy right now, nothing to explicit or detailed.
    I’m sure there are ways to do this otherwise. I would, in lieu of a perhaps better solution, save a lut or color correction setting as part of a filter package in the effects selection main menu. Then just apply that. On can then select multiple events, and once one event is “copied” (control c) select the multiple target events (control click) and then right click and select copy selected attributes. That should get you close to what you’re wanting to accomplish.
