Activity Forums AJA Video Systems MultiTrack Audio Output
  • MultiTrack Audio Output
    Posted by David Battistella on September 11, 2005 at 1:58 pm
    I know this seems basic, BUT,
    I am sending a timeline out the SDI to D-Beta with KONA2.
    Sequence has FOUR tracks of audio. I am doing a direct out
    1 to 1
    2 to 2
    3 to 3
    4 to 4
    When I lay tones on all four tracks and look at it in the Audio Tool FCP still only sees it as two tracks on output
    I have the sequence set to DUAL MONO on both channels.
    Am I missing something here?
    David
    Walter Biscardi replied 21 years ago 4 Members · 5 Replies
  • David Battistella
    September 11, 2005 at 2:11 pm
    Very odd.
    If I create a new sequence and copy paste the material in then the four tacking works, but if I change the setting s of an existing sequence then it does not work.
    I’ll send this in a s a feature request for sure.
    David
  • Ron Thompson
    September 11, 2005 at 2:19 pm
    Interesting!! You just described an old bug fix.
    4 channel output has been fine since FCP4.x (before 4.5 if I remember correctly).
    Only thing I can think of, other than upgrading software, it preference trashing or a complete reinstall of FCP5.
  • David Battistella
    September 11, 2005 at 3:01 pm
    I have FCP 5 on a completely new system with clean install. Maybe I can trash prefs but it threw for a bit of a loop. I don’t like bugs, but this one is bearable as long as it is this easy to troubleshoot.
    I’ll try trashig prefs and the POA cache.
    David
  • Kevlareditor
    September 11, 2005 at 8:45 pm
    I lay out to tape all the time this way. Sequence is 4 channel mono. But I’m using a Decklink Extereme. I don’t think It’s a specific FC5 bug.
  • Walter Biscardi
    September 12, 2005 at 2:42 pm
    Are you sure you set up the Audio Output controls in FCP for 4 channel? I’m doing four channel output all the time with our shows here with no issues.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
