Activity Forums Adobe After Effects Multiprocessor problems
  • Multiprocessor problems
    Posted by Glen Perez on December 7, 2010 at 10:40 pm
    hi, i have 6gb of ram, and a quad processor, and in the options i cannot make after effects CS5 even use 2 processors… what am i doing wrong?
    Settings:
    Installed Ram 6gb
    Ram reserved for other applications: 0GB
    Ram available for After effects 6GB
    Render multipole Frames: ON
    Installed CPU: 4
    CPU reserved for other applications: 0
    Ram allocations: 0,75GB
    Actual CPUS that will be used: 0
    then i get a message in the info panel saying: Insufficient RAM, Multiprocessing disabled.
    What´s wrong?
    Glen Perez replied 15 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Glen Perez
    December 7, 2010 at 10:59 pm
    wow things have changed…mmm well hows id the price of ddr2 these days?
  • Kevin Camp
    December 8, 2010 at 12:11 am
    more ram would be better, but i think you should be able to get mp running with 6gb and 4 cores… you might check out todd’s blog:
    https://blogs.adobe.com/toddkopriva/2010/10/please-try-recommended-memory-settings-for-after-effects-cs5-and-give-feedback.html
    he lists configuration suggestions for 4 and 8gb.
    i have 16gb ram and 16-cores (dual quad-cores with hyper threading), i’ve found leaving 6gb for other apps and 1gb per cpu seems to give me the best performance. despite ae saying it will use 8 cores, i can see it using all 16, so that info is a little misleading. when i increase ram per cpu, i can see less cpu activity (watch activity moniror or task manager to view cpu levels).
    also, never set the ram to leave for other apps to less than the minimum necessary for your os… and honestly, if you want good performance you should leave a lot more than that, otherwise the os will start using disk caching which will really hurt performance.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Deleted User
    December 8, 2010 at 3:56 pm
    From the research that I have done it seems that 2gb of ram per core is the sweet spot for a Mac Pro.
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Euphonix MC Transport • Final Cut Studio 3 • Premiere Pro CS5
  • Glen Perez
    December 10, 2010 at 4:51 pm
    i have another problem and it is that with my 6gb i can only ram render a few frames in any project, and in my laptop with 4gb i can render 3 times more frames than in my desktop… whats wrong?
  • Glen Perez
    December 10, 2010 at 5:14 pm
    q9550 quad core machine
    6gb RAM
    HD raptors
    8800GT gfx
    w7 64 just installed, no apps running
    is an HD project, can RAM preview only 6 frames… quarter quality
    Laptop is a 4GB, dual core machine,w7 64, and i open the same project in both machines… i can render like 4 seconds on the SAME PROJECT at quarter quality…
    theres something really wrong here…
  • Glen Perez
    December 10, 2010 at 5:47 pm
    Installed RAM: 6 GB
    RAM reserved for other applications: 2 GB
    and i have disabled multiprocessing…
  • Glen Perez
    December 10, 2010 at 7:13 pm
    dave, thanks for your interest, i found the solution in another webpage… i was blocking dynamic link manager in my firewall, now i can render multiprocessor and AE uses all the RAM.. im happy ;D
    and again, thanks for your time
  • Glen Perez
    December 10, 2010 at 8:25 pm
    ok, i will do it
