Activity Forums Adobe Premiere Pro Multiprocessing question
  • Multiprocessing question
    Posted by Tom Gomez on March 6, 2012 at 10:58 pm
    Just a quick question…
    In premiere with an AE comp embedded… If my multiprocessing settings are ON in AE, will it render those portions with multiple cores?
    And the premiere effects? And ME encoding? I assume those are not rendered with multiple cores?
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Tom Gomez replied 14 years, 5 months ago 3 Members · 3 Replies
  • Jeff Greenberg
    March 10, 2012 at 2:23 pm
    If you’re on 5.5, which is 64 bit (can’t recall if 5 is 64 bit) then I think, yes.
    On 5.5, if you’re using mercury accelerated fx, the video card (if you have a CUDA card that works) handles the renders (which is faster than multiple cores.)
    When you place an AE comp in Premiere Pro (again, 5.5), Premiere Pro launches a headless version of AE to do the renders – so multiple cores work. You can see this if you bring up the Task Manager/Activity Monitor (PC/MAC) and you’ll see an instance of AE launching. As I understand it, Media encoder too.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
  • Todd Kopriva
    March 11, 2012 at 2:39 am
    It’s important to distinguish between two kinds of multiprocessing:
    1) After Effects can launch several instances of itself to render frames in the background, with each instance of the application working on a separate frame. This is what is enabled by the Render Multiple Frames Simultaneously preference.
    2) After Effects can spread threads across multiple CPUs to assist in the rendering of a single frame. This is always on (unless you remove the MThread plug-in).
    When you are using Dynamic Link from Premiere Pro, the headless version of After Effects that is called to render frames uses (2) but not (1). In other words, Render Multiple Frames Simultaneously multiprocessing does not work with Dynamic Link.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tom Gomez
    March 12, 2012 at 7:26 pm
    Thanks for clarifying…
    Which is faster? By how much? Which does Media Encoder use?
    Just trying to get things fully optimized for top speed. Most of our projects are full of simple, but frequent AE elements, but we edit footage and comps in Premiere, and would like to render from Premiere and/or ME.
    Please advise!
    THANKS!!!
