Activity Forums Adobe After Effects Multiprocessing disabled: incompatible expression or effect
  • Multiprocessing disabled: incompatible expression or effect
    Posted by Tom Ma on December 14, 2011 at 5:46 pm
    I get the following status when doing a RAM preview in my comp:
    Having paid for 8 cores and 32GB of RAM, I certainly want to use them!
    Any idea how I can find out *which* expression or effect is causing this?
    Also, does this also apply to renders out of the que? (or just RAM preview in the comp)
    thx!
    Tom Ma replied 14 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Kevin Camp
    December 14, 2011 at 6:36 pm
    this portion of the manual may help you find the culprit:
    https://help.adobe.com/en_US/aftereffects/cs/using/WS9F936D13-E76A-41e4-BF8F-577132AB4723a.html
    see the portion on ‘when after effects temporarily disables multiprocessing…’
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Darby Edelen
    December 14, 2011 at 11:25 pm
    In addition to those effects noted in Kevin’s link, the sampleImage() expression will disable multiprocessing.
    Luckily there’s a way around that: Animation > Keyframe Assistant > Convert Expression to Keyframes. Make sure you do this as a last step just before rendering.
    The only way around the issue of an effect disabling multiprocessing would be to pre-render the footage, essentially baking that effect into it. If the effect is one of several effects on the layer then it might get more complicated.
    Darby Edelen
  • Tom Ma
    December 15, 2011 at 1:02 am
    yup. Lens Blur is the culprit, thanks!
    “If a composition uses any of the following effects, the composition will not be rendered with the Render Multiple Frames Simultaneously multiprocessing feature:
    Auto Color
    Auto Contrast
    Auto Levels
    Cartoon
    Lens Blur”
  • Darby Edelen
    December 15, 2011 at 1:56 am
    If you have some money to spare, and it’s an effect you use very often, then I highly recommend this plug-in:
    https://www.frischluft.com/lenscare/index.php
    It renders faster, looks better, and has more features than Lens Blur. It also doesn’t disable multiprocessing 🙂
    Darby Edelen
  • Tom Ma
    December 15, 2011 at 4:19 pm
    I have it!
    nice tip, thx.
  • Todd Kopriva
    December 15, 2011 at 6:49 pm
    The new Camera Lens Blur effect in After Effects CS5.5 also doesn’t have this shortcoming.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tom Ma
    December 19, 2011 at 10:33 pm
    that is good to know. Are the other limitations also removed.
    (I forget the exact effects, but there were a handful.)
