Activity Forums Adobe After Effects Expressions multiplying an object or composition to animate and appear in a delayed circular pattern
  • multiplying an object or composition to animate and appear in a delayed circular pattern
    Posted by Joey Campbell on July 4, 2013 at 5:26 pm
    https://vimeo.com/56510131
    Hi I have two questions if anyone could help me it would be great….
    On the above link at 4 secs the NFC logo disappears – is there a shortcut to do these diagonal lines disappearing rather than manually tweening them….if so is it a plugin or an expression?
    On the following link https://vimeo.com/45679426 at 1.52-1.54 the objects animate outwards in a circular motion delayed over time…I know that you can apply a spring type expression to get objects to appear to bounce from small to large or left to right…Can a similar expression be added to multiply one individual object so that it animates in an arc or circle with a delay ?
    Thanks Joey
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Joey Campbell replied 13 years, 1 month ago 2 Members · 3 Replies
  • Dan Ebberts
    July 4, 2013 at 6:41 pm
    The logo effect looks like AE’s Venetian Blinds effect to me.
    Expressions can’t create multiple instances of layers, but you could certainly use expressions to add time delay and angular offset to the motion of successive layers.
    Dan
  • Joey Campbell
    July 5, 2013 at 10:44 am
    Thanks Dan – I suppose i could always multiply the objects using a cloner & delay in C4D and export it with an illustrated stylized renderer. I didn’t know there was a venetian blinds feature.
    Many thanks
  • Joey Campbell
    August 7, 2013 at 8:27 pm
    Thanks – sorry about the delay!
