Activity › Forums › Adobe After Effects › Multiply one object to fill composition space?
  • Multiply one object to fill composition space?
    Posted by Jordan Davies on September 11, 2014 at 12:18 pm
    I’ve been fighting with this problem for a while.
    I have a shape (An X) that I want to pop up slowly at first, then speed up over time
    to randomly fill the entire composition space in a regular pattern. Is there a way of
    using an expression for this? Or an multiply effect that can be conformed to a grid?
    jordan.
    Jordan Davies replied 12 years ago 2 Members · 2 Replies
  • Daniel Waldron
    September 11, 2014 at 4:13 pm
    Aescripts.com has a layers2grid script that might help. I think they also have some random layer shifting scripts. You could keyframe one X to pop on, then duplicate it however many times you need before applying these scripts. Someone else probably could come up with an expression to do what you need, but I personally would just do it manually.
  • Jordan Davies
    September 12, 2014 at 10:29 am
    Hey Daniel,
    Cool thanks for the help!
    Jordan.
