Activity › Forums › Apple Final Cut Pro Legacy › Multiple video channels
Posted by Pedro Casais on June 2, 2009 at 5:33 amIs there a way to turn off a video channel without having to re-render the video renders in your sequence?
TX
PCJohn Pale replied 17 years, 3 months ago 3 Members · 5 Replies -
Shane Ross
June 2, 2009 at 5:42 amOnly if you hit UNDO when you are done. Otherwise, nope. Pain in the patoot.
Shane
Read my blog, Little Frog in High Def -
John Pale
June 2, 2009 at 5:55 amI used to be bothered by this, but I then realized that I rarely ever needed to turn off the whole track.
Just disable the specific clip (select clip, then cmd-B). Then you only need re-render the specific area where the clip was, assuming you couldn’t undo your way out of it. -
Shane Ross
June 2, 2009 at 5:20 pmAh yes, CNTRL-B…I use that all the time.
Shane
Pedro Casais
June 3, 2009 at 2:57 amThanks a lot Shane,
I’m guessing the clip enable works when you select it before turning off the viewing track, right?
best,
pc
