Activity Forums Apple Final Cut Pro Multiple versions of the same project?
  • Multiple versions of the same project?
    Posted by Michael Heckman on September 23, 2011 at 1:09 pm
    I’ve searched this forum, and know that I am not the only one who must be wondering: Other than copying the entire project file and hiding it somewhere else, is there any way to save multiple versions of the same project? Anybody who has ever made a dime editing for a client knows that it’s occasionally necessary to revert to a previous version. The lack of “save as” is a major weak spot that has been the source of many justified rants. I’m not hating– just wondering if the weakness can be overcome.
    Mark Morache replied 14 years, 12 months ago 6 Members · 7 Replies
  • 7 Replies
  • Stan Johanssen
    September 23, 2011 at 1:25 pm
    I use “Duplicate Project”. And i use it often. Probably not what you are looking for but there is (as far as i know) not any other option.
    My “projects” are stored folder-based as well.
    + Client Name
    + Project Name
    + 2011-10-11 10:02:07
    + 2011-10-10 11:02:07
    And of course with a lot of notes.
  • Tom Wolsky
    September 23, 2011 at 1:26 pm
    Duplicating a project is the save as function. It does exactly what save as does. If you want to hide projects use Event Manager X from Intelligent Assistance.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Craig Seeman
    September 23, 2011 at 3:04 pm
    What Apple needs is Duplicate Project in the File menu (just as it has Duplicate Event).
    It’s awkward to have to keep going into the Project Library to do this.
  • Mark Dobson
    September 23, 2011 at 5:09 pm
    Surely its possible also to simply file copy both the Event and Project files onto an an external drive.
    As long as the media associated with these files remains or is placed in the same original position the Event and Project files will link up.
    Or is this a flawed plan?
  • Craig Seeman
    September 23, 2011 at 5:22 pm
    [Mark Dobson] “Surely its possible also to simply file copy both the Event and Project files onto an an external drive.”
    Sure FCPX has media management capabilities.
    You can copy Project with all sources in an event or just the files used.
    You can just duplicate a Project if you want the same function as Save As though.
  • Tom Wolsky
    September 23, 2011 at 6:15 pm
    You can even move a project by command dragging it. It least you could the last time I tried it.
    All the best,
    Tom
  • Mark Morache
    September 23, 2011 at 8:29 pm
    Duplicating the project vs creating a copy in finder.
    Duplicating the project is a big FAIL because either you lose the render files in the copy, or you are forced to duplicate them all (could be many gigs).
    Duplicating a timeline in FCP7 was quick and easy, all the copies were linked to the same render files, and the increase in the size of the project was managable.
    How difficult would it be for someone to create an automation that would look for project files, and every ten minutes create a timestamped copy of the project file in a different folder?
    There are two issues for me: Actual versions and timestamp copies.
    I don’t make many actual versions, that I lock in and share with people. I’d bet that you could do alot with auditioning to create different versions within the same timeline.
    The timestamped copies could totally save my ass. There have been times when I’ve totally wiped out some of all of my tracks to the right of my edit point without noticing, because I’ve been focused in quite tightly, and I don’t discover this until I’ve executed past my number of undos.
    We could all come up with our own horror stories about how our asses were saved by the vault.
    Give us back our vault!
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
