Activity Forums Apple OS X multiple users Cleaner not working
  • multiple users Cleaner not working
    Posted by Mark Mcdonald on May 31, 2007 at 12:16 pm
    Just wondering if there is a fix for this.
    Running Mac Pro 2 x 3 ghz with 3 user accounts . Installed Autodesk Cleaner 6.5 but cannot run it in all accounts. we get an error saying batch file in use, and darkens everything out.
    This is the only program we cannot access in all accounts.
    I’m posting here because there is no “Cleaner” forum
    Thanks in advance for any help
    Mark McDonald
    wkrc-tv
    Rvanet replied 19 years, 3 months ago 2 Members · 1 Reply
  • Rvanet
    June 1, 2007 at 11:08 am
    Hello Mark,
    It could be a problem with the permission setting of the cleaner app. If I am not mistaken, you’re using Autodesk Cleaner 6.5?
    Anyway, the user account the you were using when you installed the app normally has the default permission to read and write. Try setting the mode of your “cleaner folder” in the applications folder to chmod777.
    See if it works.
    Hope it helps.
    Cheers!
    Renante
    Work fascinates me. I can stare and look at it for hours.
