Activity › Forums › DaVinci Resolve › multiple tracks
  • multiple tracks
    Posted by Andrew Sableton on February 29, 2012 at 12:52 am
    As far as I can tell the only way to view a clip in track one if there are clips on top of it in track two is to go to the conform page and turn off track 2 – is this correct?
    AS
    Andrew Sableton replied 14 years, 7 months ago 3 Members · 3 Replies
  • Kevin Cannon
    February 29, 2012 at 3:59 am
    You can go into “unmix” mode by selecting the unmix tab on the bottom right… then you will only see the selected clip regardless of what’s above it, and without any transitions…
    KC
    Prehistoric Digital
    PhD Grading Suite
  • John Michaels
    February 29, 2012 at 4:00 am
    Depending on what it is you’re trying to do, you can use the “Unmix” tab then click on the lower video clip in the mini timeline to view it.
    Edit: Kevin beat me to it!
  • Andrew Sableton
    February 29, 2012 at 5:28 pm
    Thanks…..
    sometimes the little things make all the difference….
    AS
