Activity Forums VEGAS Pro Multiple tracks with motion tracking in one project using BCC Corner Pin
  • Multiple tracks with motion tracking in one project using BCC Corner Pin
    Posted by Derek Benito on May 23, 2013 at 9:41 am
    Hi! I have Vegas Pro 11 and I am having problem loading my motion tracker to a second video.
    I am using Mocha Pro along with BCC 7’s Corner Pin effects. I had set up my first video(top most track) and its composite video below(making it compositing child of the first video). At this point, I was able to load the tracker data I made using Mocha.
    Next off, I inserted two new tracks for the second set of motion tracked video. Video 3 is the parent and video 4 is the child. I applied BCC corner pin to vid 3, setting the Corner pin source to B(which is vid 4). Then when I hit Load on the Tracker Data under Use Motion Tracker, nothing happens. Now I can’t load my tracker data to video 3. Please help. Thanks
    John Rofrano replied 13 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    May 25, 2013 at 2:26 pm
    BCC Corner Pin is a 2-to-1 Composite which affects all tracks below it which is probably why you can’t stack them on multiple tracks.
    I would place the two tracks that need to be corner pinned into a separate project. Then drop that project into your master project and apply the corner pin to that new track.
    If you are familiar with Adobe After Effects this would be called a Nested Composition which is used quite often to make multiple tracks behave as a single track.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
