Activity Forums Adobe After Effects Multiple Trackers Using Corner Pin
  • Multiple Trackers Using Corner Pin
    Posted by Christopher Pearson on November 30, 2005 at 10:39 pm
    I’ve just completed shooting a spot where there are approx. 7-10 plasma screens in each shot on the set that I’m corner pinning/compositing footage into the screens. I’ve tracked one screen and set the target to be comp’d in, it works great, but after tracking the second screen (tracker 2) and setting the target, I’m unable to see both composites (of the two screens I’ve corner pin tracked) at the same time. Note: all the screens will be displaying the same footage (therefore all trackers are directed to the same target).
    Any advise is greatly appreciated…
    Christopher
    Christopher Pearson replied 20 years, 9 months ago 2 Members · 2 Replies
  • Chris Smith
    December 1, 2005 at 5:31 am
    You will need to duplicate the footage that is place onto the screen as many times as there are plasma screens. Then do a seperate 4 corner track for each layer. If you apply the data for another track to the same layer it will just override the original position keyframes that you originally applied from the first track.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Christopher Pearson
    December 1, 2005 at 3:47 pm
    Perfect. It’s working. Thank you for the post.
