Activity › Forums › DVD Authoring › Multiple Timelines using same video Encore CS3
  • Multiple Timelines using same video Encore CS3
    Posted by Peter Young on May 5, 2009 at 2:29 am
    Any help would be greatly appreciated.
    Using Encore CS3
    I have a single video that I am using in two different timelines. One timeline plays start to end with chapter points if you want to skip. The other is accessed through a menu and is designed to play a single chapter then return to the menu. The menus, linking etc all works fine. What isn’t working is the build is creating multiple lots of data for the vid when it is used in two timelines.
    My understanding of this may be wrong but I would have thought that because encore allows you to place multiple versions of a vid into different timelines that when encoding it would only place one version of the vid on the disc. Am I wrong?
    Cheers Peter
    Roman Melekh replied 17 years, 4 months ago 2 Members · 1 Reply
  • Roman Melekh
    May 12, 2009 at 8:48 pm
    Try to use Sonic Scenarist
    You can use your video 10000 times in one project
