Activity Forums Adobe After Effects Expressions Multiple text sources from multiple markers on the same layer
  • Multiple text sources from multiple markers on the same layer
    Posted by Craig Kristensen on September 14, 2015 at 4:12 pm
    I have 4 seperate text layers which I am trying to control from a single layer.
    I can update the text by using a marker on every layer, but I need to be able to place 4 markers on a different layer and then update the 4 seperate text layers from them.
    Any ideas on how to approach this?
    Kalleheikki Kannisto replied 11 years ago 4 Members · 3 Replies
  • Dan Ebberts
    September 14, 2015 at 7:48 pm
    The text layer expression would need to be able to identify which marker to reference. If the text layers are layers 1 through 4, you could do it like this:
    thisComp.layer(“controls”).marker.key(index).comment
    Dan
  • Craig Kristensen
    September 14, 2015 at 8:25 pm
    That worked like a charm!
    You’re a superstar Dan!
  • Kalleheikki Kannisto
    September 14, 2015 at 8:28 pm
    Unless you specifically want to use markers, you could also keyframe the Source Text value on one layer and then link the others to it.
