Activity Forums Zaxwerks Multiple Text Objects at Once in Animator??
  • Multiple Text Objects at Once in Animator??
    Posted by Susan Anson on January 12, 2011 at 9:54 pm
    I would like to have 5 different Text Words each animated within Pro Animator 4.5. without having to use Premier or After Effects to string them all together later.
    I would like to animate phrase 1 to start out small, spin and then come forward and fade out…as soon as that frame exits I would like to have text phrase 2 come out from infinity and zoom past me full frame…the same with the next 3 internally generated text phrases.
    Can I load all these individual text strings into animator…or do I have to animate each one separately…export each as a movie… and then string them together in Premier?
    I can create 1 text string within animator…dont know if I can do 5 at the same time?
    Zax Dow replied 15 years, 8 months ago 3 Members · 4 Replies
  • Edward Wu
    January 12, 2011 at 11:08 pm
    Hi Susan,
    Sure. You can create as many Text Objects as needed in ProAnimator. Each Text will be in a separate Object Track. Then, animate each Object Track, for the spins, fades, and so forth. This will set up the animations for all your text.
    Best,
    Edward
  • Susan Anson
    January 18, 2011 at 1:41 pm
    Edward, sounds great. Can you give me some step detail how to begin creating these object tracks…I’ve not heard of them before. All I know to do is animate the characters in a single word right now. Thanks, sue.
  • Zax Dow
    January 18, 2011 at 7:55 pm
    HI Susan,
    We have a movie all ready for you!
    Multiple overlapping animations is covered in Movie #07 on our Video Tutorials page: https://zaxwerks.com/training/
    Suggestion: When you are learning how to do multiple overlapping animations it’s best to pick one camera position and use it for the whole animation.
    Best,
    Zax
  • Zax Dow
    January 18, 2011 at 7:56 pm
    HI Susan,
    Best,
    Zax
