Activity Forums Apple Final Cut Pro Legacy Multiple Shots Over Black
  • Multiple Shots Over Black
    Posted by Jeffrey Weiser on November 16, 2006 at 4:18 pm
    How do I do multiple shots in small rectangles over black?
    I need to create a commercial that has mutiple shots running simultaneously over a black background. The current example would be the Wachovia Bank spots running on the air. Is there a way to design this in FCP5? I would need to shrink each shot to a quarter frame or less and see the black backgound behind. So multiple shots are moving concurently. Or, do I just need to purchae After Effects and use that?
    Jeff Weiser
    David Smith replied 19 years, 10 months ago 2 Members · 1 Reply
  • David Smith
    November 16, 2006 at 4:58 pm
    Jeff,
    Read up on using the Scale and Center controls in the Viewer’s Motion Tab, it’s pretty easy. You could also use the DH_Box plug-in from Digital Heaven. In either case you would position your clips to play concurrently on multiple tracks in your sequence, then make adjustments to each one. Put a black slug full frame behind the other clips.
