Activity Forums Adobe After Effects Multiple Shapes With Defined different colours along a path
  • Multiple Shapes With Defined different colours along a path
    Posted by Alex Barnet on October 11, 2015 at 7:38 am
    Hi
    I would like to know how to make a series of circles move along a path with each circle following the circle in front of it at an equal speed/rate. I looked this up but the approaches I found were using either an expression or echo effect. The problem with these approaches is that I have no ability to define the colours of the circles. Also the echo effect has a delayed rate of speed.
    The solution I’m looking for would preferably have each circle individually animatable because I want the circles to snap to the path shape from a previous scene.
    This image shows a series of coloured circles along a polygon path which I would like to animate. (the final product wouldn’t have the circles overlapping and would be a bit neater.)
    any solutions would be greatly appreciated.
    Alex Barnet replied 10 years, 11 months ago 3 Members · 5 Replies
  • Tudor “ted” jelescu
    October 11, 2015 at 2:51 pm
    See if this helps:
    https://aescripts.com/time-offset-animation/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Ashish Gupta
    October 12, 2015 at 10:56 am
    You can try using a valueAtTime() expression in the position of all the shapes that you want following your main shape.
    The Expression would be somewhat like this:
    thisComp.layer(index-1).transform.position.valueAtTime(time-0.5) + value
    The expression works on layer index, so each shape will follow the layer above it in the timeline.
    I added value in the end, so that you would be able to edit and animate the position of each shape individually as well.
    Subtract the value from that, which you want each shape to delay from the previous one.
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
  • Alex Barnet
    October 12, 2015 at 12:21 pm
    Thanks! This seems to be working- However would you be able to clarify
    “I added value in the end, so that you would be able to edit and animate the position of each shape individually as well.
    Subtract the value from that, which you want each shape to delay from the previous one.”
  • Ashish Gupta
    October 12, 2015 at 1:16 pm
    Oops my bad,
    1. I added the (value) at the end of the expression so that you can control the individual values of shapes as well.
    2. For controlling the delay in time you can change the value from 0.5 to anything that you want.
    Ashish Gupta
  • Alex Barnet
    October 12, 2015 at 10:45 pm
    Thanks, but this started happening
    The shapes started to go off the path the longer the animation was.
