Activity Forums Avid Media Composer Multiple Sequences
  • Multiple Sequences
    Posted by Ben The camera guy on August 9, 2005 at 4:00 pm
    Hi, I am putting together a TV show and each section of the show is in a seperate sequence. I want to put all of the sequences into one sequence and render the whole thing for export to DVD format. I am using a windows machine. How do I do it? Also, what format should I render for best DVD quality? MPEG2? Any ideas? Thanks in advance.
    Michael Phillips replied 21 years, 1 month ago 2 Members · 1 Reply
  • Michael Phillips
    August 9, 2005 at 5:05 pm
    Make a new sequence load it on the record side.
    Load each of the orignal seqeunce(s) into the source side, marke IN and OUT at the beginiing and end. Edit into new sequence.
    If you want DVD, then it has to be an MPEG2 file. Depending on length of program you will set up the parameters in your MPEG2 encoder accordingly.
    Michael
