Activity Forums Adobe After Effects Multiple Questions
  • Multiple Questions
    Posted by Paul Carlin on May 7, 2005 at 10:58 pm
    1. How do you apply tracking data to the position (and rotation) of a mask? Can I write an expression to do this? I just can’t fathom that you can’t do this in AE.
    2. Can AE map keyboard shortcuts? For example… Windows/Tracker Controls
    3. Is there a parameter in expressions that measures the luminance flicker of a source layer. For example, have a Tracode LUX beam flicker in sync with a source image.
    Thanks for any tips.
    Filip Vandueren replied 21 years, 4 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 8, 2005 at 9:35 pm
    You can’t, you apply the mask to a solid, and apply position and rotation to that solid. Use the result as a track-matte
    On the mac there’s a file called “Adobe After Effects 6.5 Shortcuts”. But It doesn’t list the functionality to open that window AFAIK.
    3. Is there a parameter in expressions that measures the luminance flicker of a source layer. For example, have a Trapcode LUX beam flicker in sync with a source image.
    No there isn’t one, but I’ve heard of a plugin that can do this, I’ve never tried it though:
    Create Keys From Image
    I believe this could generate a value that changes with the luminance of certain pixels, and you can target that value in your expressions.
