Activity › Forums › Apple Final Cut Pro Legacy › multiple projects with different A/V settings
  • multiple projects with different A/V settings
    Posted by Kelly Thomson on May 13, 2009 at 6:31 pm
    Hello out there,
    I’m trying to manage multiple FCP 6 projects with different A/V settings. For some reason, every time I start a new project, it re-sets the A/V settings for all other projects. Is there a way to lock-in the A/V settings for a project? I feel like this is a glitch or I’m just missing something!’
    Thanks for any advice,
    Kelly
    Andy Mees replied 17 years, 4 months ago 3 Members · 3 Replies
  • John Fishback
    May 13, 2009 at 7:20 pm
    I guess that info isn’t saved with a project. I make a custom Easy Setup for each show that has different settings than normal.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Kelly Thomson
    May 13, 2009 at 7:37 pm
    Does this mean that every time you open the project, you check the A/V settings?
  • Andy Mees
    May 14, 2009 at 4:08 am
    Hi Kelly
    If you’re finding that managing your project settings manually for each project is impractical then you might want to check out Jon Chappell’s excellent (and free) Preference Manager helper application. It allows you to associate specific settings on a project by project basis by using the helper app as a FCP project launcher. Might be just what you need for your edit environment.
    Hope it helps
    Andy
