Activity Forums Adobe Premiere Pro Multiple projects open at the same time
  • Multiple projects open at the same time
    Posted by James Mulryan on June 28, 2011 at 1:49 pm
    Why can’t Premiere open more than one project at a time? I use this feature in FCP, very handy for consolidating footage.
    Is it because it slows the system down too much?
    James Mulryan
    Sunset Park Media, LLC
    Santa Monica, CA
    info@jamesmulryan.com
    Jason Spencer replied 10 years, 11 months ago 8 Members · 7 Replies
  • 7 Replies
  • Chris Knight
    June 28, 2011 at 2:43 pm
    Premiere has never allowed opening of more than one project file at a time – but you can merge as many as you want, using the File->Import command. This probably isn’t a solution for everyone (since any changes you make to an imported sequence, won’t have any affect on the original project file).
  • Vince Becquiot
    June 28, 2011 at 8:39 pm
    James,
    You can also copy and paste in between projects.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Charles Fasano
    July 15, 2011 at 5:58 am
    I also require to have multiple projects open simultaneously. It’s because I have a project just for business files, a seperate project that houses music to be used in multiple files, etc… I set it this way when I was a FCP user which allowed multiple projects.
    Is there a workaround?
  • Gates Bradley
    September 19, 2012 at 3:28 pm
    I know this thread is quite old, but I imagine there is. At the post house where I used to work the post supervisor enabled it so we could have 2 after effects projects open at the same time. I’m not quite sure how he did it, but I am going to look into it. I just remember it seemed he tricked the computer into thinking there was a second iteration of AE.
  • Jon Collins
    March 23, 2015 at 10:00 am
    I’m a bit late to the party on this, but this has been an issue that annoyed me as well. I however found a work around which I’ve written a quick tutorial on over here: Opening second instance of Premiere Pro.
    Jon
    Jon Collins
    Director // Editor // Motion Graphics
  • Kevin Clancy
    June 22, 2015 at 8:32 pm
    Hi Jon,
    I’m having this problem too, and was excited when I saw you found a work around, but when I clicked the link, it didn’t work. Do you have an updated link?
  • Jason Spencer
    October 9, 2015 at 6:22 pm
    I found Jon’s blog with the same info. It’s not the smoothest option (no fault of Jon’s – this is something Premiere should let editors do) but it does the trick.
    Here’s the link: https://ukjoncollins.com/video-editor-blog/post/how-to-run-a-second-instance-of-premiere-pro
