Activity Forums Adobe After Effects Multiple parenting
  • Multiple parenting
    Posted by Marten Kopp on May 12, 2009 at 9:34 am
    First off all, I dont know if this is the right forum for my question. But I post it anyway.
    I am trying to create an arm witch is connected to a pencil.
    The problem is that I need a specific movement. The pen wil emit particles and it’s going to be moving around. But the sholder should be staying at its position with every movement.
    Is there a way to get the sholder (body) fixed at its position and only let it rotate around the pivot depending on the position of the upper and lower arm?
    I hope my problem is clear. I could explain in perfectly in dutch but you guys wouldnt understand that haha.
    Cheers
    Marten Kopp replied 17 years, 3 months ago 2 Members · 2 Replies
  • Bartek Skorupa
    May 12, 2009 at 9:46 am
    This is called “Inverse kinematics”.
    You can’t get it straight in AE, but I recommend you take a look at:
    https://www.motionscript.com/expressions-lab-ae65/ik.html
    Bartek Skorupa
    Warszawa, Poland
  • Marten Kopp
    May 12, 2009 at 9:55 am
    I allready thought I needed to go to the expression forum. But this will help me out big time!! Thanks for the help and quick reply!
