Activity Forums Zaxwerks multiple objects?
  • multiple objects?
    Posted by Dave Cannon on August 27, 2008 at 7:19 pm
    I am new to Pro Invigorator. I am attempting to build an animation with three lines of text being used as independent animatable objects. In the user manual I read about a pull down menu in object mode with Object 1, Object 2,…. All I see in my application is a pull down menu with Set 1, Set 2,…. I have tried to create the independent text objects by selecting Set 1 for the first line of text. I then switch to Set 2 and select “Create 3D Text”. The application ignores the fact that I have chose Set 2 and applies the text directly on top of the Set 1 text, merging the two together. Seeing that the user manual is pretty unclear on this subject, could someone shed some light please?
    Deleted User replied 17 years, 11 months ago 3 Members · 4 Replies
  • Dave Cannon
    August 27, 2008 at 9:56 pm
    Spoke to the man himself, Zax, @ Zaxwerks. Thank you for clearing it all up for me 🙂
  • Deleted User
    September 10, 2008 at 7:01 pm
    Glad that he helped you out. Could you explain it to the rest of us because I don’t get it.
    Geno A. Palazzari
    Creative Services Commerical Producer
    KAAL-TV
    Rochester, MN
  • Serge Hamad
    September 11, 2008 at 1:20 am
    Invigorator assigns all objects to Set1 by default.
    If you want to assign an object to a different set, you need first to select the object in the Set-Up window then choose another set in the Set menu. It’s as simple as this;-)
    Salut.
    Serge
    Invigorator/Proanimator Training Review:
    https://library.creativecow.net/articles/murphy_kurt/invigorator_tr_rev.php
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Deleted User
    September 11, 2008 at 1:30 pm
    Thanks for your help. I am sure I will have more questions, but this will get me going for a while.
    Geno A. Palazzari
    KAAL-TV
    Rochester, MN
