Activity Forums Maxon Cinema 4D Multiple Object Connect
  • Multiple Object Connect
    Posted by Shinsei Hosking on April 26, 2011 at 8:27 pm
    Hey there,
    Im trying to connect my 3 objects which make a whole figure (each have a texture and bump) but when I do, the figure has weird black shades to them…
    You can see from the image:
    Shinsei
    ED_QuickJap
    x
    Dan Fredley replied 15 years, 4 months ago 2 Members · 2 Replies
  • Dan Fredley
    April 27, 2011 at 6:45 am
    I’m pretty sure it’s because you have different phong angles on the different parts, so when you combine them only one phong tag gets applied to the single object. Try 22.5 degrees on that single phong tag. If that doesn’t work then I’d suggest being happy with separate objects or someone more experienced than myself will need to help.
    Dan Fredley
  • Dan Fredley
    April 27, 2011 at 6:52 am
    Or it might be that your UV meshes or materials are being combined in a weird way. Not sure how to combine those cleanly.
    Dan Fredley
