Activity Forums Maxon Cinema 4D multiple object boole intersect
  • multiple object boole intersect
    Posted by Paddy Fernandez on November 4, 2011 at 10:43 pm
    Hi, im trying to find out how to create a shape from the resultant intersecting shapes, its easy to do with 2 shapes as you just use a boole A intersect B but im trying to do it with 8 shapes and not having any luck.. have included a picture to hopefully make it a bit clearer about what i am trying to do. any help would be fantastic.
    thanks
    Paddy
    Paddy Fernandez replied 14 years, 10 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 4, 2011 at 10:56 pm
    Stacking should work. Try unchecking the high quality box in the bool objects.
  • Paddy Fernandez
    November 4, 2011 at 11:18 pm
    Hi Adam thanks for your help but unfortunately that hasnt worked…
    I have uploaded the scene file, if you have a spare minute to have a look to see if you can figure it out that would be soo helpful.
    https://www.sendspace.com/file/gosism
    Paddy
  • Brian Jones
    November 5, 2011 at 12:12 am
    assuming you want all the intersections of all the cameras and not just ‘what is the volume that all the cameras share’, you’re going to have to make copies. They don’t all intersect so if you take (for example) pyramid 3, 7 and 8 in your file and put 3 and 8 in a boole you get a result but if you put that result in a boole with pyramid 7 everything disappears since the 3-8 result does not intersect with 7. To get both intersections you would need to duplicate 8 and boole that with 7 separately and so on.
  • Paddy Fernandez
    November 5, 2011 at 12:19 am
    that makes alot of sense, will be quite the puzzle! cheers for your help brian
    Paddy
