Activity Forums Apple Final Cut Pro Legacy multiple naming in browser
  • multiple naming in browser
    Posted by Alan Mccormick on July 16, 2008 at 2:50 pm
    Hi, new to FCP and have come across a niggly problem that hopefully someone that works using the same feature can correct.
    Scenario: I use the browser and name clips and also add comments in say the “shot/Take” and “master column 1” columns for example. Now FCP has a nice feature where you can name one shot/take then select the other clips that are the same (cmd +click) and by “right” clicking in the column you want to change it will present you with a list of any previous text added in that column.
    Excellent you would say (I did :)) – until I found that the list is NOT sorted in any shape or form.
    Now with say 20+ different names say in that column it become more of a hindrance than a real asset.
    So! does anyone know how to solve this or have I missed an easy method in front of me – I have searched without avail so far.
    Alan
    Alan Mccormick replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 16, 2008 at 3:33 pm
    Don’t think there’s a way to change this behavior… might send feedback to Apple.. from the FCP menu…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Alan Mccormick
    July 16, 2008 at 4:04 pm
    Thanks Jerry, I had a funny feeling that would be the answer
    Alan
    Regards
    Alan
