Activity Forums Adobe After Effects multiple masks?
  • multiple masks?
    Posted by Chris Straus on September 21, 2009 at 6:31 pm
    i have an image on which i have created a mask to hide a section of it. i want to create a second mask on that same image that hides another section. when i try this the second mask doesnt work. the first mask hides the appropriate spot but with the second mask, nothing happens. any ideas anyone? oh i am on after effects 7…
    thanks.
    Scott Novasic replied 16 years, 7 months ago 3 Members · 2 Replies
  • Jeff Klein
    September 21, 2009 at 8:02 pm
    Select the layer and hit hit MM (M twice quickly) on your keyboard and that will open the mask properties. Next to each mask there is a drop-down list that says “Add” by default, on the second mask try changing that to something else (either subtract, intersect, or difference) depending on what you’re trying to accomplish.
  • Scott Novasic
    September 22, 2009 at 4:22 am
    hit subtract in the mask modes
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
