Activity Forums VEGAS Pro Multiple Masks on One Event?
  • Multiple Masks on One Event?
    Posted by John Perez on June 30, 2020 at 10:51 am
    I have created two masks on an event but they won’t show up at the same time on the mask timeline. At one point in the timeline I have one mask then when I move down the line I see my second mask but the first mask disappears. How can I have them show at the same time for the duration of the event time? Thanks!
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    John Perez replied 5 years, 10 months ago 2 Members · 3 Replies
  • Francois Pénzes
    June 30, 2020 at 12:57 pm
    Hi John
    Could it be that they are both on the same timeline and not on separate ones ?
    Event #1 has Gaussian Blur applied with only Alpha channel checked.
    Event #2 has Gaussian Blur applied with green channel un-checked.
    Both are using masks and are distinct and independent of each other.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Francois Pénzes
    June 30, 2020 at 1:04 pm
    … and yes, I’m using V12 for this demo. This will work in all versions.
    (As stated in previous posts, I don’t use my work comp for web stuff.)
    Cheers !
    Radeon RX 5700 XT
  • John Perez
    June 30, 2020 at 10:34 pm
    I think I got it. It looks like I created the second “eye-hole” further down the timeline, but this time I made sure to create the second mask of the eye-hole at the same point on the timeline. (Duh!) Thanks for helping me out with such a quick response. you’ve helped in previous queries and I greatly appreciate your help!
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
