Activity Forums Adobe After Effects Expressions Multiple linear() in an expression
  • Multiple linear() in an expression
    Posted by Martin Schmid on December 1, 2025 at 10:37 am
    I’m trying to have multiple linear() ramps defining a value at different times…
    My arrays seem to be all being defined correctly… however, when I try to conditionally set the ram (see note in all caps below), I’m not getting the expected results… what am I doing wrong?
    beats_per_min = 104
    sec_per_min = 60
    beats_per_bar = 4
    seconds_per_beat = sec_per_min / beats_per_min
    section_bars = [0,2,8,8,4,8,2,8,4,8,2,8,8,9,8];
    // set the bar number at the end of each section
    section_bars_cum = new Array(section_bars.length)
    section_bars_cum[0]=0
    for(arrIndex = 0 ; arrIndex< section_bars.length-1; arrIndex++)
    section_bars_cum[arrIndex+1]= section_bars_cum[arrIndex]+section_bars[arrIndex+1]
    // set the time(in sec) at the end of each section
    section_time_cumulative = new Array(section_bars.length)
    for(arrIndex = 0 ; arrIndex< section_time_cumulative.length; arrIndex++)
    section_time_cumulative[arrIndex]= section_bars_cum[arrIndex] * beats_per_bar * seconds_per_beat
    // compute each linear()
    var linears = new Array(section_bars.length)
    linears[arrIndex]= linear(time, section_time_cumulative[arrIndex], section_time_cumulative[arrIndex+1],100,0)
    /// THIS IS WHERE I AM HAVING ISSUE
    // try to aggregate all the linear()
    if(section_time_cumulative[0]>= time && section_time_cumulative[1]<=time)
    linears[1]
    else if(section_time_cumulative[1]>= time && section_time_cumulative[2]<=time)
    linears[2]
    Yoan Boisjoli replied 8 months, 3 weeks ago 2 Members · 1 Reply
  • Yoan Boisjoli
    December 2, 2025 at 3:47 am
    Hi Martin!
    I might be wrong since I haven’t tested your setup directly, but I think the core issue is that linears[] isn’t a function. When you do:
    linears[i] = linear(time, t0, t1, 100, 0);
    linear() is evaluated immediately, so each linears[i] just stores a number for the current frame. There’s nothing to “call” later.
    Your range checks also look inverted. You probably want:
    if (time >= t0 && time < t1)
    instead of
    t0 >= time && t1 <= time
    A simple pattern that might solve it is to calculate the ramp only for the active section:
    for (i = 0; i < section_time_cumulative.length - 1; i++){
    t0 = section_time_cumulative[i];
    t1 = section_time_cumulative[i+1];
    if (time >= t0 && time < t1){
    value = linear(time, t0, t1, 100, 0);
    break;
    value;
    Hopefully that points you in the right direction.
