Activity Forums Adobe After Effects Multiple Leave Color effects on a single layer?
  • Multiple Leave Color effects on a single layer?
    Posted by Cwolfe on February 16, 2006 at 3:58 pm
    Recently had a session where it would have been really nice to have multiple leave color effects on a single layer. I work with NBA footage and leaving the blue AND red from a jersey would have been sweet as opposed to just the blue. I tried layering chroma keys but the noise was problematic.
    Any ideas out there?
    Thanks in advance
    -Chris
    Cwolfe replied 20 years, 7 months ago 4 Members · 4 Replies
  • Mylenium
    February 16, 2006 at 4:36 pm
    Not really. Leave color always works on the currently active pixel buffer after all effects that come before it (in order to circumvent this, it would have to have an explicit layer selector). Similarly other effects fail. Your best bet is to use Shift Channel to extract multiple solid colored portions of your imagery, but there obviously are limits to its effectiveness.
    Mylenium
    [Pour Myl
  • Phil
    February 16, 2006 at 4:50 pm
    COULDN’T YOU APPLY THE LEAVE COLOR EFFECT ON TWO DIFFERENT LAYERS, & THEN USE “KEY OUT DARKER” TO COMBINE THE TWO?????……….
    I’VE NOT PLAYED WITH THIS, BUT IT MAY WORK (?)
  • Roland R. kahlenberg
    February 17, 2006 at 12:27 am
    I’ve got a COW tutorial that does just that. Take a look at the COW tutorials section and search under Roland Kahlenberg.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Cwolfe
    February 17, 2006 at 1:55 pm
    I knew there had to be a clean, clever solution. Thanks to all for there replies and especially to Roland for this elegant solution!
    -Chris
