Activity Forums Adobe After Effects Expressions Multiple layers randomly appearing
  • Multiple layers randomly appearing
    Posted by Johan Tornlund on January 6, 2008 at 1:01 pm
    Hello! Here’s a problem I’ve been trying to solve for quite some time now.
    I am trying to create a matrix of layers that goes from 0-100% opacity from left to right.
    I think it’s difficult to describe this effect with simple words so I have manually keyframed the effect and rendered it out as a short example video.
    It happens very fast but if you go frame-by-frame you can see what kind of effect I’m trying to achieve.
    shapes video
    Basically I want the layers to “pop up” from left to right, but at the same time be influenced by a little bit of random delay.
    Is there an expression that would do this for me?
    Johan Tornlund replied 18 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 6, 2008 at 8:54 pm
    If you have your layers sequenced (In Points set to where you want the layers to appear), this should work:
    rampTime = .5;
    ease(time,inPoint,inPoint + rampTime, 0, 100)
    If they all start at time zero, something like this should do it:
    sequenceTime = .4;
    rampTime = .5;
    beginTime = (index – 1)*sequenceTime;
    ease(time,beginTime,beginTime + rampTime, 0, 100)
    Adjust rampTime and sequenceTime as needed.
    Dan
  • Johan Tornlund
    January 7, 2008 at 12:11 am
    Dan, thank you for trying to help me with this.
    I realize now however that I forgot to mention a crucial part of my problem.
    What I really need is an expression that will duplicate a layer so I won’t have to do it manually.
    To be more precise, it is exactly what was mentioned in this thread:
    https://forums.creativecow.net/readpost/227/9041
    Your answer to that thead was that it isn’t possible unless one were to use the shape repeater. Luckily in my case all of the layers I want to duplicate are in fact shapes. The only problem left is to make them randomly appear across the screen.
    I can think of it as several shapes swooping by sideways that leave duplicates as a trail. And on top of that, each one of those shapes have a wiggle applied which affects their velocity.
    Wow that sounds really confusing, and I’m starting to question if the amount of work required is worth such a small effect. I might just resort to using your first expression instead, since it basically did the trick only without the random velocity. But either way, thank you for your time.
