Activity › Forums › Square Box CatDV › Multiple Ins and and outs?
  • Multiple Ins and and outs?
    Posted by Scott Coulter on August 22, 2011 at 6:56 pm
    I’m just wondering, is it possible to have multiple ins and outs on a single clip? I’m guessing (if it works) it will just be split up into multiple versions of the same clip. Thanks!
    Matthew Stamos replied 15 years, 1 month ago 3 Members · 3 Replies
  • Bryson Jones
    August 22, 2011 at 7:16 pm
    Not to my knowledge. The process would be to create subclips and use those.
    Although you could use “range” markers in the event marker’s area as that.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Scott Coulter
    August 22, 2011 at 7:22 pm
    Thanks! I’ll see what works best.
    I’m just jumping into CatDV, so it’s been an experience.
  • Matthew Stamos
    August 22, 2011 at 7:49 pm
    You can use the convert markers to sub clips command. This would likely make a few more sub clips but would speed up the process for longer format master clips.
