Activity Forums Adobe Premiere Pro multiple in and outs on the same clip
  • multiple in and outs on the same clip
    Posted by Gary Linzer on October 8, 2010 at 8:04 pm
    I want to make a number of different in and out points on a single clip. I know I can do that in the source window by dragging down the clips into a timeline. My question: is there any way to mark different in and out points from a single clip but without dragging each marked clipped to the timeline? I’m using CS5.
    Andrew Devis replied 15 years, 11 months ago 2 Members · 1 Reply
  • Andrew Devis
    October 10, 2010 at 5:44 pm
    The only thing I can think of is to create sub-clips for each selection you make in the source panel. That way, each selection will become a separate item in your project panel to use as and when you are ready to use it.
