Activity Forums Adobe After Effects Expressions Multiple if/then statements
  • Multiple if/then statements
    Posted by William Marler on October 20, 2013 at 8:32 pm
    Hello there,
    I am wondering if it is possible to apple more than one if/then statements to the same layer. For example, I am wanting to “fence” an object to the bounds of the composition, or use it in other situations.
    I have separated the dimensions of a layer, and tried to apply two if/then statements to it, saying if the x value is bigger than the edge of the comp, make it stick to the edge of the comp, if it isn’t bigger, do nothing. I am wanting to apply a second if/then statement for the other side of the comp, so I have one for the left side, one for the right side and two additional ones on the y dimension.
    if (transform.xPosition > 1012) 1012 else transform.xPosition;
    if (transform.xPosition < 268) 268 else transform.xPosition;
    Daniel Futerman replied 9 years, 1 month ago 3 Members · 3 Replies
  • Dan Ebberts
    October 21, 2013 at 2:11 pm
    You just need to string the first else and the second if together:
    1012
    else if (transform.xPosition < 268)
    268
    else
    Dan
  • William Marler
    October 21, 2013 at 2:14 pm
    Ahh, that’s quite elegant actually. So you you string them together with if1, else1-if2, else2-if3, else3-if4, and so on? 🙂 Thanks for your speedy response.
  • Daniel Futerman
    August 1, 2017 at 4:12 pm
    Dan, I can’t count the times I’ve turned to your answers for help. This is just one example.
    Thanks for all your help throughout the years!
    After Effects Template & Photoshop Tutorials:
    https://amigo-productions.com
