Activity Forums Blackmagic Design Multiple HDLinks
  • Multiple HDLinks
    Posted by Charles Caillouet on May 2, 2009 at 12:58 am
    Is there any way to control more than one HDLink with one Mac?
    My Multibridge utility has a device menu but i don’t see any provision for more than one device in the HDLink Utility.
    I want to use two HDLinks as live SDI color correctors for remote cameras.
    Do i need two computers to do this?
    C. R. Caillouet
    Vision Unlimited/LA
    HD Production Technical Support since 1987
    …searching for the right tool for the job…
    Charles Caillouet replied 17 years, 4 months ago 2 Members · 2 Replies
  • Kristian Lam
    May 6, 2009 at 1:59 pm
    The current HDLink software only controls one device. However, the settings do stick even when disconnected from the USB connection if that helps.
    regards
    Kristian Lam
    Blackmagic Design
  • Charles Caillouet
    May 6, 2009 at 4:02 pm
    Kristian,
    Thanks for the response.
    That’s about what i had figured out.
    And the settings hold well. I swapped cables back and forth between two units on my last job. I will just have to add a USB switch to the mix.
    crc
    C. R. Caillouet
    Vision Unlimited/LA
