Activity Forums Apple Final Cut Pro Legacy Multiple FW Devices on iMac FCS Setup
  • Craig Thomas quinlan
    June 2, 2009 at 3:50 am
    Using a hub or repeater won’t increase the performance of your firewire drives. You’re still sharing a connection and a single FW bus no matter how you do it.
  • William Carr
    June 2, 2009 at 5:07 am
    What is the difference between these repeater-hubs and a regular multi-port hub? The Nitro unit specs say their repeater provides for “an elimination of daisy-chaining”.
