Activity › Forums › Adobe Encore DVD › Multiple Flash DVDs in Same Directory
  • Multiple Flash DVDs in Same Directory
    Posted by Accountclosedduetonorealnameused on November 5, 2007 at 5:47 am
    Here’s what I’ve found so far:
    Webpage + XML always must be in the same directory.
    HTML must reference the SWF file.
    SWF + Source folder always must be in same directory.
    This poses a major problem: All XMLs exported use the same name, so you can only have one XML around each webpage and therefore one FlashDVD per site directory.
    Has anyone found any workarounds to this? (maybe making the SWF reference the XML from the SWF file’s location instead of the webpage <_< )
  • Joe Bowden
    November 5, 2007 at 2:08 pm
    How about using another directory? Why is that a problem?
  • Accountclosedduetonorealnameused
    November 10, 2007 at 3:12 am
    Well several reasons – I really wish I could but it would virtually kill the setup of my site.
    1- I’m trying to show multiple flash videos on the same page (so they would use the same index.html)
    2- I’ve put a few into a gallery, which uses dynamic URL (PHP page generated from the same index file). The entire site allows commenting and has a user database etc (like the forums here) so I can’t exactly copy-paste the page for just one upload.
  • Joe Bowden
    November 10, 2007 at 9:17 pm
    Encore’s export to Flash is a one-size-fits all approach – there’s really no way to do what you want with it in CS3.
    You might want to try using Flash itself. It’ll be a lot more work (a LOT, LOT more work), but you’ll have full control over everything.
    November 10, 2007 at 9:29 pm
    Hm ok.. that’s what I was afraid of… hopefully Adobe addresses this later on. 🙁
