Activity Forums Adobe After Effects Multiple Flares Linked to Layers
  • Multiple Flares Linked to Layers
    Posted by J.d. Vaillancourt on February 9, 2012 at 5:14 pm
    Hi, I have a large object scrolling across the screen, I would like to have multiple flares flashing that are linked to the motion of the object. Problem is when I pick whip each flare to object, the flares obviously default to the anchor point of the layer. Is there an expression to offset where on the object the light source location locks to or a better method to do this?
    JD
    Jon Bagge replied 14 years, 6 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    February 9, 2012 at 6:07 pm
    You can create an Expression and then add an offset value to each flare’s position property (not the transform position property).
    Something similar to this –
    (value[0]+200,value[1]+50)
    FWIW, Parenting may seem to be the easiest but since flares have their own position parameter, Parenting will almost always lead to the flares being cut off – unless the flare layers are sufficiently large.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jon Bagge
    February 10, 2012 at 7:08 am
    Pickwhip the position of the layer like you did, but before pressing ‘enter’ add ‘ +value ‘ to the expression.
    This will add the value of the parameter the expression is applied to. You can now re-position the flare as you like, and it will still move with the other layer.
    https://www.jonbagge.net
    Jon Bagge – Editor – London, UK
    Avid – FCP – After Effects
