Activity Forums Maxon Cinema 4D multiple falling text crash
  • multiple falling text crash
    Posted by Dragan Maric on August 15, 2011 at 7:23 pm
    Hi,i have a problem creating 3 falling text on a solid floor.
    I want to achieve that; first text fall on floor,after that second text fall on first text and break first text.And after that third text is falling onto second text and break second text.
    I m using free plugin nitro blast from nitroman.
    Dragan Maric replied 15 years ago 2 Members · 2 Replies
  • Brian Jones
    August 16, 2011 at 3:47 am
    this is one way, texture is different on the objects to make it obvious but make it the same and you don’t see the change. I dropped the first text then did a Current State to object to give me the text to be broken by the second text. It’s just a matter of turning tags on and off and making objects visible and invisible. Done with Thrausi not NitroBlast though so maybe it has something else that’s possible.
    2810_thrausibreakdroppedobject.c4d.zip
  • Dragan Maric
    August 16, 2011 at 2:23 pm
    Thank you very much,this is exactly what I want!
